- Aug 18, 2007
Your question is not very clear. When you say "the 2MOVE underpowers them" are you referring to the JVC as "them"?
If the JVC shelf system is "them" and you are feeding the signal from the 2MOVE?, and you now want to switch from feeding the 2MOVE into the JVC and use the Travagans to feed the JVC speakers, then I don't think you will get much of an improvement.
If you are getting hiss, turn up the 2MOVE volume and turn down the JVC volume and see if that helps. The 2MOVE is very quiet, so I suspect the hiss is coming from the JVC shelf system. The lower the volume knob is set on the JVC, the lower the hiss should be.
Now, if you are planning to get the Travagans Green to connect to laptop instead of the 2MOVE, you could connect the speakers to the green directly and the hiss would go away. You would not need to use the 2MOVE or the JVC shelp amp anymore.
Originally Posted by rhy /img/forum/go_quote.gif would all of these be capable to use with an old jvc shelf system i have? i've got it connected to an old 2move using one of these right now (can't remember what these are called): 2move connected via usb to my laptop. i think the 2move underpowers them and there's a little more hiss than i'd like which may or may not be be the amp's issue. not sure about this stuff as i just began this setup. this thread just caught my interest with all the speaker talk. i'm just interested in an amp/dac combo that can drive both headphones and speakers adequately. |
