I gotta give props to whoever makes the drivers for these headphones.
Basically, I'm using the HD681Evo drivers for a project of mine, bought a pair of these just for the drivers, sort of threw the rest of it away, because I just need the drivers for a 3D printed headphone I'm currently making, and basically, this project involves super gluing a piece of plastic onto a magnet of the driver to hold it tightly in place and stiffen in to reduce vibration, just at this point, it's too messy to keep it like that forever. To make this story short, I didn't glue it properly, pulled on it to remove it, and the motha*****ing magnet popped out. It just fell out with a slightest tug, as if it was held inside the socket by another weak magnet. Great, there goes a driver I thought (btw, I ruined a Sony XB500 driver and a Sennheiser HD438 driver exactly the same way, apparently the glue used to keep the magnet in is very weak, so be careful around that area), but nope.
The driver was fine, the voice coil was untouched, so I decided to put the magnet back in, and then ran into problems, somehow, in some weird way, the plastic hole for the magnet shrunk, because the magnet didn't fit in anymore. I scraped all of the yellow rubbery glue out of that socket, sanded the magnet to make it clean and shiny, and then comes the reason why I give praise to these drivers (and my 3D printed baffle which is strong enough be ran over with a tank and survive, apparently, despite being light as a feather, woooo for my engineering skills). I managed to squeeze that magnet back into the hole with such force that I thought I'd break the floor underneath the driver, let alone the driver itself. Basically, think of a 90kg heavy guy using all of his strength, focusing the entire force through one thumb and shoving down on the magnet into the hole. It went in, and not a single piece of that assembly cracked. Amazing. Despite being held by just very thin plastics, that driver frame is strong as a rock. HD438 and Sony XB500 drivers snapped like toothpicks with 1/10th of the force. Just for a comparison...
So props to Superlux, their headphones might be cheaper than pretty much anything else on the market, but drivers are incredibly tough. Might I also add that it sounds exactly the same as before I broke it, it measures the same, etc. And it sounds wonderful, even at this early stage, my frankenstein headphones sound considerably better than a stock HD681Evo and are in 300+ dollar territory in terms of sound. These drivers have incredible potential but are ruined by the cheap design and build of the stock headphones.
