Nomis22
- May 7, 2011
Thank you both for your quick answer, it's been very helpful : I'm ordering the IE from LendmeURears right now !
(so happy...)
(so happy...)
hello
short question:
do the Xcited and Xcape IE come with the same type, size and form of tips like those which come with the RE-0/-ZERO ?
thanks
thanks
then how are the HiFiMan bi-flanges compared to the meelec bi-flanges for m6 or a151. i find those meelec to big for my ears
im sorry that i keep asking
i dont mind if they're longer , in length
but are they also wider then the meelec's , in the big flang of the bi-flages?
sounds like a NO hifiman for me.
are the hifiman small size bi-flanges the same?
also, can you suggest a bi-flange similar to the shure/etys triplets?
thanks and sorry for getting out of the thread topic
got those meelec bi-flanges and they really big.
btw, from that photo with the 3 sunrise and the zero housing looks like the strain reliefs on the xcape v1 housings is softer and more flexible. the xcited's and X-IE's looks similar just a but larger and more straight. while the hifiman's looks very stiff like if it was made of plastic
