Gurdipurdi
- Apr 9, 2010
How small are people's ears. 1+2 I have to use the smallest tips and I was still able to get a se5.This small
https://dl.dropboxusercontent.com/u/275840/SE%205-way%20Molds.pdf
They look quite normal/average to me. Not big, not small.
Have you been specifically told by someone that you have small ears..?
Hi Geert,Your impressions have arrived, thank you.However, your canals are too thin to make it for the 5-way’s, unfortunately, as presumed. Moreover, the canals might be too thin to make anything in silicone, not just the 5-way’s, because of the fact that silicone is flexible and the canals would bend too much (they are very thing and long), preventing you from inserting silicone monitors into your ears at all.Therefore, if going custom, I’d suggest trying non-flexible, acrylic monitors, perhaps.Sorry about that and thank you very much for your interest once again.
Well yes, by Grzegorz actually. This is what he emailed.
I am so happy that I'm about to join this big yet small family!!!
Grzegorz:
"Fortunately, it will be possible to make the 5-way's for you with some protrusion. Luckily, the conchas are capacious and their shape, structure and symmetry allows it, though barely and it's still quite difficult to make it."
Thank god, it finally worked!
Big thanks to my audiologist too, for using up a whole tube of impression materials to fill my whole ear upon my request!
Big thanks to Tupac for "lending" me his address and poisoning me every now and then during these hard months with his se5 impressions so that I did not give up trying.
Finally, HUGE thanks to Grzegorz for making this miracle happen, I never thought my ear size would fit se5way! Oh and also for the super fast speed 1 week production time!!!
Grzegorz:
I am trully interested in this pairing. ..tell us mooooooooooore.
Thanks Joe for the awesome review.
Thanks Tupac for everthing you did for me (and to me).
Thank everybody on this forum for their truthful and unselfish sharing.
This is an engineer marvel in 21th century.
Oh, these, both of them, the player too, actually.
And when you pair them together, heaven's open, angels fall, falling down into my ears : )
So far, I have none of the issue mentioned before.
It is not dark at all. But it is less bright than, say, the sennheiser HD800.
The bass quantity is never too much, less than my JH16 for sure. In fact, you might even find it bass lacking on some tracks if you are used to bass heavy headphones.
Sound stage is not narrow at all, deep and 3D.
The vocals, however, at higher listening volume, stands out of the rest a bit for some recordings. For others, no issue at all.
The most amazing thing is the attack and decay. The naturalness of each note is superb, organic indeed.
