Tulku1967
- Jan 6, 2016
But then, this thinking only applies if ultimate realism is the goal to be achieved here. Although I very much strive for realistic reproductions of sound from my IEMs, I also need them to align to my personal tastes, my personal definitions of realistic/reference/fun, etc., and that is achievable through the precautions I take when reading reviews by someone like Nic, who happens to have similar tastes, definitions of sound, and IEMs as I do, if a direct audition of the IEM is not available to me, e.g. the SE5U. Artificial music, although filled with synthetic instruments, effects, etc., can still become either pleasing to the ear or downright harsh or terribly muddy depending on the IEM you use; it doesn't automatically become irrelevant simply because it can't be compared to real-life instruments and therefore doesn't have an "absolute reference". Using live performances as a reference is also tricky because you have to have attended both the live concert and heard the recording of that concert, and then compare the recording to your memory of the concert, assuming your aural memory is 100% accurate. Another problem is what you're hearing as an audience member in a live concert is sound directly from the instrument plus what is captured through the mics/DI and reproduced through the PA system plus reverberations and frequency response changes caused by the acoustic, while what you hear in the recording is captured directly from the mics/DI and then further mixed and mastered, so differences will definitely be present. You do know that a lot of live concerts are recorded with close-mic-ing of the instrument, and that reverb is more likely to have been added in post, right? So, I believe, in the grand scheme of things, it's more efficient (to both the mind and body) to form your own internal frame of reference as to what sounds "good" to you (whether that means realistic, fun, bright, warm, or, in my case, somewhere in between all of that) and understand what qualities in an IEM can give you that. But, as always, YMMV
I agree with so many things!
It is perfectly legitimate if a person with a similar character is relevant to you.
If you have the same opinion on the sound of matching technical devices, then this is even better.
I also agree with the section on recording live music.
So go for SE5 ULT!
Ps: How do you know that SE5 ULT will win the race?
