I don't think there is a universal BT driver in Android. Different headset uses different BT controller and as far as I know,individual driver come from different chipset manufacturer and can be quite different in quality. I have had problem with my Lenova android tablet before and that's the info I dug up back then. Guess that's can be said as an android thing...
[REVIEW] Sony MW1 - Smart Wireless Headset pro
- Thread starter ClieOS
ArcMhyke
- Apr 14, 2013
I Tried reverting back using SUS, results still the same, sound have a sec delay when playing games.
I also have MW600, when using it on Xperia Arc with 4.0.4 there's no problem, but when i use it on Xperia SL or Xperia Ion both 4.0.4, there's also a delay, then i thought that it could be the bluetooth core version, MW600 have 2.1 while Xperia SL have 3.0, so when i look at MW1 it has Bluetooth core 3.0, and i thought that it might fix the problem, but no avail.
Only when streaming games, Calls, Music and Playing video's are fine though.
I think it is an android thing?
Jurisprudence
- Dec 30, 2011
I can't comment yet on the MW1 sound quality yet as another poster has as I haven't bought it yet but I must say coming from an iPhone 4, Blackberry Playbook, PS Vita and Sony Vaio Duo (which has a very powerful sound itself) the SQ from the HTC One has been fantastic and for me clearly superior to the other devices mentioned.
I'm using Triplefi !0vi's with Sony tips which deliver a more prominent mid and treble than Complys TF 400's and while I didn't get a chance to EQ the One properly (its gone back to be replaced due to faulty construction) I was hearing a soundstage which took my iphone and dropped on it from a height. Mids and treble were crisp and while the base was lessened due to the Sony tips it remained defined and fluid rather than buried and indistinct. For someone looking for a competent music player/phone combo I've heard none better than the One. HTC's (now former) slogan "Quietly Brilliant" needs to be replaced with something that really shouts regards just how good the One's HP amp is for music lovers.
Do you actually prefer the One's hp-out to the MW1? I haven't read a lot of reviews but I've yet to see anyone comment on the supposed cotton amp even tho it was one of HTC's PR bullet points. Even Anandtech didn't, I think, and their phone reviews are easily the most exhaustive.
kevinpwhite
- Apr 5, 2007
Slight digression... has anyone with the MW1 discovered whether it will support .wav (or perhaps flac) files in addition to .mp3 ?
Also if so is it possible to navigate the files as pseudo CDs (ie. if stored in directories mimicking a set of CDs by artist, etc.)
Many thanks,
regards,
Kevin
Many thanks,
regards,
Kevin
Wave and mp3 are the two supported format and you can browse music stocked on MW1 by Album, Artist, Track, as well as playlist (created by Sony MediaGo software).
Many thanks,
regards,
Kevin
NewForce
- Apr 30, 2012
Oh my.. Sony MW1 seem like still stuck in the same situation with the old MW600, their BT are so buggy.
I've thought their BT should work perfectly with their Sony cellphones. Look like I'm wrong.
Wondering what's wrong with Sony Bluetooth division?
Just double checked at Sony discsussion site, Sony team still have no solution to fix the problem yet.
http://talk.sonymobile.com/community/support/phones/accessories?view=discussions&start=0#/
Actually I find MW1 works smoother with Sony smarphone than Samsung. Try unpair your MW1, then uninstall the smart headset pro app. restart your smartphone, make sure your smartconnect is up to date, then reinstall smart headset pro app, then pair the MW1 again. Also if you are on E firmware, revert back to D to improve stability.
- Jun 26, 2001
Sorry for not replying - Yes, most definitely - especially since the latest firmware update (1.29) - It easily gives my NWZ-Z1060 & Fiio E12 setup a run for its money (and, in some situations arguably beats it!)...
A real plus point, and - something that BT will not be able to beat... The MW1 that I favoured so much with the iPhone has now been relegated to sitting on the side...
Do you actually prefer the One's hp-out to the MW1? I haven't read a lot of reviews but I've yet to see anyone comment on the supposed custom amp even tho it was one of HTC's PR bullet points. Even Anandtech didn't, I think, and their phone reviews are easily the most exhaustive.
NewForce
- Apr 30, 2012
You might be right about incompatibility. So far i have only encountered problems with Sony BT stereo. My other experience with Moto S705, i.Tech 803 and Samsung HS3000 was ok with most of my Samsung cellphones. Btw, thanks for your tips.
NewForce
- Apr 30, 2012
One thing I did not mentioned previously, the Sony MW1 was not belong to me, and i considered myself lucky already.
Well, for those of us who are still stuck with MW1 happily, a new firmware E (from v0.1.E.1.4 to v0.1.E.1.5) can be found on SUS.
I don't think E.1.5 solves the stuttering problem either.
kevinpwhite
- Apr 5, 2007
Thanks very much for the complete reply.... much appreciated
Regards,
Kevin
Regards,
Kevin
This looks like a MW1 stepdown, with extra NFC support but not as good an IEM (MH1-> MH750). No more mp3/wav player and still no aptX as well
SBH50:
SBH50:
NewForce
- Apr 30, 2012
To me, it seem like some of the Sony back dated design products (may be already 2years old) finally see the lights, approved by the management to roll out to market. Well, seriously SRS-BTX300/500, both aptX and NFC enabled bluetooth speaker are the newer design offering and better buy bluetooth products from Sony.
Both of them not as chic as Samsung DA-F60, though.
