Feb 6, 2013 at 11:36 AM Post #16 of 22
I would think the bass might be a bit weak for Trance, but it depends on how much bass you like. Overall it is a better IEM than EB950 no doubt.
Ok thanks mate, I found a place in UK that sell them at an amazing price. So I guess I'll go for them once I sold my Sony W273.
I'm not really worried about the low bass since I'll be using them with my E11 amp which means I can adjust the bass response.
Now I like the R-50 with EDM whether its trance, house, techno or what ever.  The bass on a flat EQ is to light but with my E11 or E6 bass boost on I can get the bass to have a good amount of impact and much better depth than stock.  The R-50's detail and precision works good with EDM imo but if you really like a good amount of bass I wouldn't use the R-50 then, something like the BA200, GR07 or e-Q5 would all be better, I had all 3 and I liked all of them to use with EDM.
Thanks man.
Well I've got my eye on the R-50s because of their awesome price, plus ClieOS has them rated at 4th place. That's quite something.
Feb 23, 2013 at 8:19 AM Post #18 of 22
How does R-50 compare against [size=11.111111640930176px]DBA-02 MkII?[/size]
I can' say for sure. I don't own the DBA-02 MK2 but only audition it quite some time ago. I'll say it is a minor upgrade over the original DBA-02 so it should be more or less around the same level as R-50 for overall SQ.
Feb 23, 2013 at 8:23 AM Post #19 of 22
Thanks, I ended up ordering the SM64, talking about impulse buying. Hope it turned out to be good. I know you dislike earsonics sound signature so hopefully I wouldnt be disappointed much as I seem to have the same taste in SQ as you based on your reviews.
Jun 17, 2013 at 7:35 PM Post #21 of 22
Both Joker and ClieOS have these rated the highest SQ for $120 or less, yet this thread is not getting much action.  Why is that?
