earlinarizona
- Mar 24, 2005
Does anyone know how many ma's the sr71b puts out per channel to the headphones? It is not listed in the spec sheets I have been looking at.
I meant mW on the last post and not m amps. For example the VAMP puts out 150 mW at 32 ohms, Same question on the Portaphile 627. No specs on there sheets.
Any updates on the sound of this amp, perhaps with current revisions, on HD800, HD650, and LCD2 and 3?
Between the hpp1 vs clasdb..i think they both very similar in sound (as a dac) although i feel like hpp1 is slightly warmer while the clasdb is slightly brighter and more detailed. But the difference is barely noticeable unless with a very serious listening in a very quite room. The hpp1 has a bigger power lineout...meaning the gain of your amp will be increased when connected to hpp1 line out. The clasdb works the other way around. Somewhat the gain of the amps will be reduced by just a bit when connected to clasdb. The good about clasdb..we can use balance connection between clas and amp. This will not gives u a large improvements..but rather just a slight improvement in soundstage, better ambience, fuller sound and more open sounding. And for the best...you might want to use balance connection all way through.
Thanks for the information. That helps me to decide on whether the clas would be worth it, and gives me a better idea about what to expect when I get the amp to test it. At $700 I wish I had a way to demo a balanced output dac like the clasdb to compare my hp-p1 with, but I don't right now. My IEMs aren't hard to drive at all, and the 71-B has power to spare from what I've read, so it sounds like I will need to be very careful about volume adjustments with it.
I've been told that even with a single input to dual conversion that my setup should have a very noticeably improved SQ, but we'll see about that when everything arrives and I get to try it.
could anyone direct me to where you guys are buying your balanced headphone plugs for DIY? searched but cannot find. any help is apreciated
About the on-cable plug for Ray Samuels Audio (RSA) portable balanced amplifiers:
- The novel aspect of RSA amps is the innovative use of a particular connector to provide a balanced interface of small size.
- The connector is normally used for cameras but has been shown to work very well for this purpose.
- Ray sells quite a few of these amps. The amp I am using is relatively new and top-of-the-line, very powerful.
Plug Dimensions:
Attached is a PDF with full dimensions, excerpted below.
Judging from this drawing, the opening for the cable is 4mm. This might limit its use to Clear Light, unless creative termination and stress-relief might find a workaround.
Pin Definitions:
From Ray Samuels (rsaudio@raysamuelsaudio.com)
Left Channel:
PIN # 1 is POSITIVE
PIN # 3 is NEGATIVE
Right Channel:
PIN # 2 is POSITIVE
PIN # 4 is NEGATIVE
Pin definition for the socket in the amp. Reverse this to view from outside.
Pin definition for the plug. Viewed "through" the back of the plug.
Physical Orientation:
The pin definitions is consistent with the physical orientation below, which avoids interference with the volume knob. See picture:
Supplier:
Mouser #: 163-191J-E
Mfr. #: 163-191J-E
Desc.: Phone Connectors CAMERA PLUG 2PC cable size 2-4
http://www.mouser.com/ProductDetail/Kobiconn/163-191J-E/?qs=C8m%252bmemFVBP34xgvdBuhwA==
http://www.mouser.com/catalogviewer.aspx?page=1389&highlight=163-191J-E&catalogculture=en-US&catalog=646
