AudiophileAri
Sponsor: Audeze
Member of the Trade: 1MORE, HELM Audio
- Nov 9, 2015
Hi Moedawg
I haven't had any problems with upgrading - these are the steps I got from Bruce over at Questyle
The QP1R has new firmware that is fixing some small bugs and improving performance, here is how to upgrade the firmware to your QP1R:
- Follow this link to download the firmware http://questyleaudio.com/download and load it onto onto a blank MicroSD card (it is less than 32MB so it doesn’t have to be a large card).
- Install the card into TF Slot 1 on the QP1R.
- Go into “System Settings”, scroll down to “Upgrade” and push the select button,
- “Yes” should already be highlighted in blue, then push the select button and the update should start.
- Once it finishes, the player will automatically reboot.
