RPB65
- Oct 11, 2015
I've done blind tests with various cables in the past and couldn't hear a difference. I don't expect to suddenly start hearing those differences now, so there isn't much point in me continuing to test them. I mentioned that many others felt the same, as this is a contentious issue that has two strongly opposed camps and I think it's only right that a prospective buyer who has noted he has concerns about spending large amounts on a cable upgrade realises this.
I think my suggestion for him to try before he buys is completely reasonable![]()
"Contentious issue", "two strongly opposed camps" are regardless of what I am attempting to convey to you. Your suggestion for him to try is not the issue, what is, is talking about something that you haven't listened to with regards to stating others experience negligible if any differences. Again, if you haven't listened to what is being discussed, please don't make assertions (especially about other's opinions) about something that you have not listened to.
What is with you? you in a bad mood to harp on everyone? Crafty said he tried cables and "FOR HIM"....which is his opinion....he can't hear a difference between the cables he's tried. He also took a point saying there are two camps, and therefore it is up to the individual if they hear differences or not? what's wrong with saying YMMV? He's allowed to share his experiences here.
I've voltage-matched cables for direct A/B testing and compared to a stock cable, a well-built cable can make a difference. Most comparisons aren't volume-matched, which is a big part of the reason why I'm neutral on the topic since different cables will have different impedances, even if you have two of the same models. When a replacement cable costs the same, or more than the headphone itself though, I think there are issues there. XD
On the topic of the QP1R, one issue I have with it is the responsiveness of the volume knob compared to what the software recognizes. For example, if I adjust the volume in my pocket, I can feel it click X times, but the volume doesn't actually change X notches.
I agree with your first paragraph.
With regards to your second, what version firmware are you using?
Version 1.07 is what's loaded on here. If you adjust the volume knob or scroll wheel one at a time, slowly, all of the clicks coordinate with the software, but if you scroll more quickly, that's where it seems to fall behind.
e.g. if a loud song suddenly plays in your playlist and you need to turn the volume down a lot, splinning the volume knob quickly doesn't necessarily correlate with a fast change in volume being played
Thanks for the response. I'm aware in previous versions, the volume clicks didn't coordinate very well with the firmware, but the later versions got better in this regard. Probably because the QP1R is translating the analog movement into digital movement. I usually just go with how I listen and adjust accordingly. I also listen with High Gain most of the time so I don't have to turn the volume knob very much to reach a desired volume level/position.
Ah okay. I'll see if updates fix it!
Hello again all,
I find these two usability features quite annoying on the QP1R:
- The volume knob is 'backwards' compared to all others; counter-clockwise increases the volume
- The2-33-4 second 'screen lock' after changing volume is horrid and counterproductive
Any tips / solutions for these?
Other than that, I've been testing DSD with this baby and absolutely this is a world class performer as a portable player in that regard and there are no traces of delta-sigma glare / harshness. This too also benefits from an external amp (such as the FiiO E6 matchbox sized portable amp) for increased smoothness / realism / soundstage, but interestingly the sound of the matchbox sized amp with the QP1R was nearly just as good as when connecting the QP1R to a summit-fi home headphone amp system via line-out.
Hello again all,
In the settings you can change the rotational direction of the volume knob
