Skylab
Reviewerus Prolificus
UPDATE: auditioning of KICAS non-Caliente (regular) version
Oriel at Purity Audio was nice enough to send me a regular KICAS (non-Caliente version) to audition. The plan was to compare it to the Caliente side-by-side, but this was not to be, as unfortunately I loaned my Caliente to another head-fier who has vanished with my amp
I did spend some time listening to the regular KICAS, though, and from memory I will say that I was quite surprised that it sounds much more similar to the Caliente than I expected. The regular KICAS is still very smooth, nicely detailed, with an a very neutral, even sound. It is neither bright, nor bass-deficient. Just as I found the Caliente not to be overly warm, I do not find the KICAS to be overly lean, or even lean at all. It's smooth and pleasant to listen to.
In almost every way the KICAS and Caliente sound very, very similar. Without being able to do a direct comparison it's almost impossible to define exactly how much difference there is, as I am certain that the difference between the two is quite subtle. If one has slightly lean headphones, it makes sense to get the Caliente, and conversely the regular KICAS would be the way to go if one has warm-ish headphones. But in neither case is either Purity Audio amp so colored that matching is all that critical. I enjoyed both versions with all the headphones I tried.
