I'll add a couple of cents worth of notes about the PA2V2 — assuming that's what the P2AV2 note referred to — and if anyone is curious. If there is a P2AV2, then please correct me and accept my apology. Hope SkyLab doesn't mind my answering the question, since he hasn't heard it.
The (Electric-Avenues.com) PA2V2 is a marvelous entry-level amp that has plenty of power in a tiny, simple, square black plastic box (2.6" x 2.6" x 1.1"). I think it's currently $60 + small shipping cost, comes with an AC adapter/charger, runs on 2xAA rechargeables for roughly 100 hours, depending on battery capacity. It's also sometimes available at ebay auction, obviously for less than $60 if you're lucky.
The abbreviated specs are: an LM4881 op amp, 2x470uf Panasonic input caps, 2x2200uf Panasonic output caps (forgot the models); has an output power of up to 200 mW RMS; claimed 5Hz-40kHz response; 100dB SNR. I'll try it tomorrow with ES2 IEMs to check for hiss.
It's been a while since I listened to it, but I'll try tomorrow with DT880-250/05, PXC300 and ES2, and adjust this post if needed.
It has a gutsy sound and can drive most phones, but lacks refinement, solid image focus, and the kind of transparent window into the music that we're all seeking, and discussing here.
Still, it provides a big, energetic sound suitable for the beginner on a budget. It's not a contender for top SQ positions, but I don't believe it makes any such pretentions. It's simply a nice introduction at a very painless price, and an unassuming yet durable package.
I try to keep products in context, and appreciate them for what they offer in that context.
EDIT 9:07am: Unfortunately, the PA2V2 is not a match for the ES2 IEMs. In terms of hiss there's only a very tiny hiss that the music covers, but the sound is noisy and gritty. [Perhaps an impedance mismatch?] The overall sound with ES2 is worse than iPod 4G headphone out. Though iPod headout has no depth or "life", it's cleaner and more pleasant than PA2V2. Not the proper application for PA2V2. (Sorry, Gary.)
Tomahawk, on the other hand, is a wonderful improvement over iPod headout with ES2! Better separation, imaging, extension, definition, dimension, air, etc.
EDIT 2:30pm: Okay, here's the (overall positive with caveats) quicky low-down the PA2V2 with PXC300 and DT880-250/05.
The PA2V2 drives the DT880-250/2005 quite well, with surprisingly good extension and a better illusion of depth & dimension than I expected. One apparent area where it falls short — using the Hornet for comparison — is highs on violins and voices, where some fringe-y edges are heard, whereas the Hornet is smooth and sweet. It also falls short in clean, crisp leading edge attack and bass definition.
It has good bass energy and impact, but it's less defined. Placement of performers and imaging are also better than I recalled, though the ultimate lack of clean edges & transparency prevents it from presenting the rock solid, well-described, layered imaging that the best amps offer.
Still, the PA2V2 is pretty involving and a terrific bang-for-buck amp.
I was using Sting's "Brand New Day" disc, "Desert Rose" (for high metal persussion, swooshing L-R effects, depth/dimension, bass and drum attack. On "A Thousand Years" that starts out with a stygian bass-synth note, it reproduced the note pretty well. I used Maxim Vengerov "Virtuoso" disc, "I Palpiti" for high/smooth solo violin, and Alison Krauss "Lonely Runs Both Ways", disc, "Gravity" — where Alison's voice and Jerry Douglas' dobro were just smoother & sweeter, the bass richer & punchier, and the overall sound cleaner & more fluid with blacker background with the Hornet.
PA2V2 is a great match for the (closed/folding/Noise-Reducing) Senn PXC300 phones, which makes for excellent iPod/amp/phones portability without IEMs.
