HardstyleLoco96
- Jan 21, 2014
Thanks for the help, I shall have the 10 within 2 weeks or less. Can't wait!!!
For you guys who are using PowerAmp Alpha, is the Hi-Res Output working for you? When I enable it, it will seem to work for a bit, then when changing tracks for fast forwarding a track playback will stop and I get an error message saying something like "Hi-Res Output failed". Sometimes if I push the play button a bunch of times, the track will start over but not always. So I've been disabling the Hi-Res Output for now. Any ideas? I really liked that feature as most of my FLAC files are 24bit/96khz needledrops from my vinyl collection. That feature made PowerAmp Alpha the best sounding player on my LG V10. I'd really like to get it working on the HTC10 before my return period is over. Still trying to decide which phone sounds better and which I should keep....:confused_face(1):
What's wrong with capactive buttons?
I have no problem using Onkyo HF player or power amp alpha with the 10 and can still use high-red to feed pha-3
Other than turning on the High res option on the HTC 10, do you do any other setting changes?
Okay. I have a V10, which is one of the phones mentioned in the .703 release notes as being supported for hi-res. And for me, it works no problem. I get all my flacs in 24/44.1.
Other than turning on the High res option on the HTC 10, do you do any other setting changes? I'm just trying to help out others, who seem to be having trouble getting it to stay on.
Like I said, it worked great on my V10. When I installed the v.703 on my HTC 10, I made sure all the settings were the same from the V10. I even tried changing a few but it makes no difference. Sometimes it will play 4-5 songs in a row with no problem, but if I change albums or fast forward I get the cannot play error. It's even worse if I have it on shuffle. I guess they have to make some changes to the program for it to be compatible with the HTC? Could that be because of the rumored DAC in the HTC 10? We still don't have s straight answer on whether it has a dedicated DAC or is just using the Snapdragon, right?
Is there a program to display the audio output of the Android system in real time, so I can try some other music players and see which is outputing in native sample rate, and not downsampling to 48kHz? I've seen people post screen shots but I'm not sure what program they're using or if it's a hidden menu in Android
I meant the high res option in Poweramp Alpha.
For my V10, which is one of the supported phones, when I turn that function on, I get my 16/44.1 and 24/96 modes confirmed on that screen. If I turn it off, PowerAmp uses the standard android API, and it samples to 16/48. The reading at the bottom of the playback screen is the original sample rate, not playback.
