- Oct 6, 2013
Thanks for your help, I knew this, but Wokei has convinced me that to get an amp
Yeah, blame it on Wokei
Yeah, blame it on WokeiSeriously, amp is a great idea to have and NX1 cost peanuts. I would like to hear you impression once you get it and how much does it actually enhances the sound from LO of X1, not just making it louder but actually adding dimension to a sound, more details, wider soundstage?
Have the IM-03 on order, have a question (maybe a noob question)
I noticed on many IEM's with removable cable, the pins are housed in the cable ends but with the ATH units, the pins are housed in the IEM itself. Is there any specific reason for that? (I know people say it locks pretty securely)
That's not a nooby question at all!
For example, the old Westone cable...
The main reason that came to mind is that having the pins on the cable itself makes for a weaker joint. Now, fans of the "old" Westones will probably tell you that the cable is just fine, etc., but in the hands of a somewhat more careless individual (there's those of us out there...), it is conceivable that he/she may accidentally snap the cable in place. Furthermore, the cable design that AT opted for is the 2 pin, which is much weaker than the MMCX model. Just wiggling the cable around can cause the two pins to either warp or damage internal components.
Now, I'm not saying that this isn't possible with the new fire-wire style ATH-IM series cables, but it is much less likely I'd say.
Part of the reason why this is all possible is because of the relatively bulky housing of the IM series, which makes it possible to contain the pin inside the earphones. The Westones and Shures have a true negative profile, making it very difficult to do the same thing.
Now, I'm not too sure about the engineering benefits. If anyone wants to chime in, that'd be great.
I'm really happy to inform that this little mod is just brilhant!!!
I had already enjoyed the im50 sound sig, but felt the bass a bit loose sometimes and the mids where somewhat "hold back" by something.
Then I remove the filter with a needle and.... WOW!!!!
Every single aspect just got better!! I really enjoy how it sounds now!!!
Even the instrument separation and bass tightness improved substantially.
I have a vsd3s too, and prefere the im50 sound sig by miles!
However, the fit, size, confort and isolation from vsd3s are still the best.
Thanks for the tip ozkan!!!!!
You're referring to the foam like material in the nozzle, right? I always assumed it had some sort of dampening background... Does the removal of this piece have a similar effect for the other IM series models? It'd be hard to return it once removed..
Yes, you can apply this mod to all IM series. I haven't tried this with other IM BA series but it works perfectly fine with IM50/70. And you can always put back on the filters if you don't like the sound as there is some glue around the filters. The mod is reversible.
Ah, but as I recall the filters on the non BA series are thin disc like structures. This is not the case with the BA series. The 01/02 filters could be described as wool being stuffed into a tube.
Yea, definitely not a great idea to remove them on the BA series, especially if you have resale in mind. To be honest, this mod seems like it would turn the BA series into a wooly/foamy disaster. Would use caution...
Anybody gonna try the latest $70 Lunashops cable? Still need enough impressions on the $40 one and what it does for the IM series.
