- Oct 14, 2013
Shure olive tips don't fit to IM series.
Oopsie stand corrected. Thank you !
Agreed, silicon and hybrid tips are the best for this line
Avoid Comply tips at all costs! Any audio technica iem I have heard is terrible with them.
Buy Sony hybrids. They are perfect for me.
What's the hybrid part of the Sonys? I'd prefer a foam tip because the Silicon that came with the IM02 will not seal, M or L. If I get a seal, it only lasts for a few minutes. This is with clean canals too.
If the Sonys have a foam-ish element, I'll go there. Otherwise, I'm still very curious about the Complys.
Where do you buy them? I can't find anything but shady Amazon stores.
In terms of balance, does the Piston 2.0 have more bass or the ATH-IM50? I found that the bass was too strong on the Piston (and Zero Audio Basso), messing up the balance. The OP says that IM50 has the maximum tolerable bass; I'm just wondering if earfonia tolerates more bass than I do!
So I was messing around with my FiiO X5 after updating its firmware, and I wanted to listen to it, since I haven't done that much since I bought the AK120ii. I wan't in the mood to bother switching the cable on Angie back to single-ended, so I grabbed the ATH-IM03 instead.
Can't seem to take them out. Nearly through OK Computer by Radiohead, and don't plan to stop there.
That's a damn good album!
So you feel the IM03 have very good synergy with the X5, then? Is this the old X5, or the 2nd Gen version?
Does anyone here own both the IM 02 and the DUNU titan? I'm having a hard time deciding between the two. I mainly listen to classical music, but is also into jazz and world music. Recently, I have taken a liking to Creedence Clearwater Revival as well. I like something that is neutral, but with a bit of bass. So I was really looking to try the Titan. The only deal breaker is poor isolation and no over-the-ear design. The IM-02 seems to be my kind of sound as well, and like the form factor. Which one do you think would be better?
