mikeaj
- Jan 10, 2010
This was where I was going to go as well. The high gain should sound pretty much identical to the low gain unless the high gain is causing clipping (and the input stage will clip no matter what the volume control is set to, if the input is too high), which is very plausible with many sources. Default high gain is 6.5X. If the source outputs any more than say 1.07V, it will clip with that gain. Most DACs really shouldn't be outputting more than 2.8V but if they do, they'll clip the default low gain of 2.5X as well.
Definitely if the low gain and high gain sound different (uh aside from the volume difference) on the Clip or Fuze, or if you've otherwise confirmed you're not clipping the input stage with whatever it is you're using, something is up.
Originally Posted by limpidglitch /img/forum/go_quote.gif
[snip]
If you can hear an audible differance between high and low gain, that is not attributable to either sound level or channel imbalance, I dare say your amplifier is defect.
