maverickronin
- Apr 5, 2010
Voldermort has the gain and battery or AC specified on most (if not all) of his measurements so you can decide for yourself.
The short answer is that the AC pretty much just gives you more power and raising the gain increases the noise and distortion a tiny bit. You'd have to use an amazingly high gain before it became audible though.
Is there any advantage to using it at the higher gain settings if you can get enough volume on the pot at 1X on low impedance or high impedance headphones?
Is there an advantage to using the AC adapter as far as speed of bass transients or anything? It's just so low distortion and clean on batteries I haven't even bothered with plugging the adapter in yet.
