Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Very very briefly. Sounded pretty much as an LCD-2 should. Very strong and thumpy.
The XS are normally used with 3.5 mm jack into the left cup, however the right cup has a 3.5 mm jack socket which can be used connect to another set of headphones so 2 people can listen at the sametime, I wonder if i could have a custom cable made with 2 X 3.5 mm jack to 2 x 3 pin XLR would this work into a HA 200 mono block set up ? as it might take a while to get to the cans i would like to have
need to find a cost effective balanced dac first, then the right cans ( Alpha Dogs, TH 900, TH 600 and or Audeze 2.2)
then we will get an second HA 200 (Insha'Allah God Willing), however, the XS are good however they need gentle soft music that does not push them dynamically
