- Apr 28, 2007
By the way, anyone reading this page should take a detour to read Larry's most excellent post, over here.
Great read. Glad I opted for the LX over the DACport. At least from what I've read from other members the LX is more transparent and the overall better value... Plus combining it with a dedicated amp it will sound even better across the board. Listening right now from and L3 Triad and it sounds amazing.
The LX it's a great DAC for it's price, this baby can drive my DT880/600 ohm effortless, and it will drive my HE500 soon as the HE500 arrived
You don't use an amp with it? I use an amp. Too worried about possibly damaging my IEM or my ears lol. I hear its not good to do direct connecting to it for some reason.
At first i don't believe the LX could have a good synergy with the DT880/600 ohm since the LX only powered by an USB port, but when i tried it ohhh boy the LX can make the DT880 sing beautifuly
It's pretty much paired quite nicely with everything I've thrown at it. It's extremely neutral and transparent. I love the mid range the most on it .
RUNNING AMPLESS
So you no longer get the convenience of being able to plug headphones and IEMs straight into the DACport LX the way you do with the original DACport. But testing the unit reveals that things still sound good, even as I try plugging anything from a Hifiman RE-272 IEM to an Audez’e LCD-2 headphone (Yes! the big Orthodynamic!) to the LX’s output socket. Volume control is done on the digital domain via iTunes. No breaking up of sound, no distortions, no frequency rolls off, only a noticeably weaker bass punch compared to the DACport’s output jack since we’re running the headphone straight from the DAC’s analog stage. This is what Michael Goodman says about it:
“The output stage is buffered, but you may be maxing out the buffer that way. We recommend that LX is followed by amp with a higher input impedance. But it won’t get damaged the way you are using it, so it’s ok.”
I’m not suggesting that you run on that configuration, but you can get away with it as long as you can bear that bass punch is not as punchy as it’s supposed to be (though bass levels are not an issue with the LCD-2).
Hey Everyone,
Please note price changes for DACport ($300) and DACport LX ($250).
-Kenny
Would be sweet if you could get 24/192 support on the DACport and DACport LX .
You guys are never happy
