Please,
Could someone could share further information regarding the stock headphone Hifiman HE-560 cable beyond the
"a premium cable comprised of crystalline copper and crystalline silver".
Thanking you in advance.
cartrufer
Well the key word in that sentence was "crystalline", wich I believe means OCC wire, the best quality.
But it's all for nothing,
because of both the short length, and the winding. .
The winding means everything.
The isolation of the strands with rotation(litz) also means everything.
A Litz type twist wich also isolates and coats each strand is best..
The twist means no wire stays in center.. an optimal design (maximum surface to conductor ratio).
Without isolation and winding we don't achieve linear progression of electrons, that always prefer riding the surface of the conductor..
Only a heavier draw forces them to flow thru the center which is usually wasted. (bottleneck effect)
Silver plating takes advantage of this "surface preference" of electron flow,
but without the separation of strands,
they act as "one conductor",
and we have this bottleneck effect with less surface to conductor ratio.
As you can see where I am leading to?
IMHO, A litz type braided cable will have moe "surface to conductor" ratio and thus more linear eletron movement.
While this whole post is my own viewpoint, it is not without merit and is a reason why cables sound different.
Transient attacks and spacial cues "may" make up some of perceptual differences that not easy to measure but affected by cables. ...
4 strands of copper wire and 4 strands of silver wire afaik. So both a silver and a copper cable, actually.
It is a waste to me if its not braided litz. .
