ethan961
Member of the Trade: Bugden Audio
- Mar 16, 2008
I haven't read the link but it's the opposite. IEMs, especially BAs, tend to have less impact and bass than speakers. The reason is that BAs are totally sealed, and they can't move much air because they are sealed. Dynamics are not sealed and have vents that allow them air to move. Speakers typically have all the air they want. Dynamics can move more air allowing for more tangible bass, whereas BAs tend to give you better quality bass but you don't feel it as much.
I have both of them. The details on the dba02 are definitely better. When i first got the dba02 I didn't really feel that it was much of an upgrade over my re0. But since my re0 was away on RMA i couldn't do a direct comparison. After listening to the dba02 exclusively for a few weeks and ab-ing them with the re0 when they were back from RMA, i realized i was wrong.
I always thought the re0 had one of the best reproduction of details, but the dba02 did it better. Like someone said before ( i think), listening to other phones after hearing the dba is like putting on an ill prescribed glasses. Everything seems less focused and ill defined. Violin notes on the re0 sounded somewhat fuzzy and blur as compared to on the dba. On the dba you can hear the friction between the bow and the strings which can get really addictive. The definition and detail reproduction is really on another level.
Whether you think they are worth the extra cost depends on you. You'll always encounter diminishing returns when moving upwards but imo the extra $60 was worth it for me as i really appreciate the added balance and definition among other improvements.
Are you amping your RE0? When amped, they are anything but undefined. I know armatures are even sharper sounding, but that's not necessarily a better presentation. For example, I much preferred the soft, smooth sound of the RE0 over that of ultra sharp q-jays. I also prefer RE0 to Ortofon e-Q7 out of my Audigy 2 ZS - e-Q7 sounds sharper, but RE0 is more natural.
