mcnoiserdc
- Mar 26, 2010
well I have bought a few items from GD-audiobase and still no problem at all, 100% happy with costumer service.
Definitely not a user error, clogged filters, moisture, etc. in my case. Either the drivers or the crossover is defective. I guess it's the risk that one has to take
Quote:I don't think anyone's had an issue with GD. More with the NA distributor. I doubt there are even 2% that get shipped with a problem of some sort. It's almost always going to be clogged filters, moisture, forced nozzles and tugged cables. Perhaps some of these happen too easily with the DBA and could be avoided with a different build but you get what you pay for and these issues can still be tallied to user error. It wouldn't stop me from buying them.
That's all fair enough. Still, IDK, about the 2% thing. My order from GD was in the low 300s, seems like we shouldn't be conjuring stats out of remote places.
Look, I'm not saying don't buy, I'm saying, know there are QA issues (and it will take about a month +1-2 weeks to send them back to Russia) and delays with getting stock/potential fit issues.
No one can quantify the risk for your set of circumstances, ears, time budget and wallet, but yourself.
No conjuring. Opinion as in 'I doubt'. Not claiming this happened but you can clog a filter the first time it gets inserted and never get a chance to hear them right. Apparently this was an issue and why they moved the filters. Like I said, it could be better designed to avoid this stuff but I don't see why the defect rate should be higher than anything else using similar bits.
lol. you guys sound slightly disturbing with the whole earwax affair. I prefer to clean my ears after showering... Probably because I use IEMs daily, I suppose...
precious IEMs and filthy huminz - NEVUR SHARE!1oneone
Funny, reminds me of the first time I let someone try my Etys. Upon first insertion the tips got clogged full of wax. Like they got dipped in Marmalade. I was in awe.
The only problems I've had with no sound on one side have been not having them properly inserted and the end of the tip gets pinched closed. My big problem is finding a tip that's fits my ears. I've given up on foam tips because I destroy the tip every time I take it off. I'm afraid one of these times it'll be the post that breaks instead of the tip. Shure single flange tips work OK, but they don't isolate enough. The big flange on the Shure triflange are too big and hurt. 45 minutes is just about the limit of what I can stand. I've tried cutting off the biggest flange but then the tip is really to short and the whole thing doesn't work with my ear geometry. I've ordered the large and small Ety triflange. They're showing up the first day I'm gone for a week.
THERE'S A DBA-04?!
