ethan961
Member of the Trade: Bugden Audio
- Mar 16, 2008
I may get reprimanded for this but I finally was able to dismantle the outer housing of the monitors to wipe my stinking sweat off. It wasn't too hard actually. Here's how it looked...
Was kinda risky, I know, but I just had to do it. You can actually pry out the rubber stopper to access the internals but didnt do it to prevent any damage. This just shows that sweat can really gain access through these cracks and openings since they are not sealed
The rear rubber portion is sealed - you may have disrupted the seal while taking off the clear back. I've taken apart many DBA and that black rear portion has always been sealed well. The only place fluids could get in are where the wire comes out and the nozzle. It is possible to get fluids in through where the black portion meets the blue portion if you try, but definitely not enough to cause a problem unless you drench them for hours or something. I apply some of a special fluid to that portion in order to dissolve the glue used to hold them together and seal them.
