Took the new DBAs on all day flight travel today. I'm still figuring out the fit. Like I posted before, the Comply T100 work best for me. I can't stress enough, getting a good fit/seal is imperative to getting a good sound out of the DBA. If you don't get a good fit, it sounds like AM radio with no bass. To a degree, I think that's what a lot of people are experiencing with the sharper highs.
Very interesting sound signature so far. I'll do a proper burn-in when I get back home. My RE0's sound anemic in comparison. If the DBA was a touch warmer, they'd be my IEM "Holy Grail". Definitely one of my overall favorites right now.
Right.
Now take what I said earlier and tone it down a bit... just as these have.
The biggest change came within the first half-hour of play. After that, not much sonic change... except for tip, insertion and seal variables. Kind of as usual.
It really was a harsh graininess in the upper-mids and highs that seemed to smooth out with a very short amount of time. I really only had a couple tips with me for the listening session and the full tip comparison sessions will occur gradually or this weekend when I have more time...
Meanwhile, here's what I learned. (But it's still day 1, so things can and probably will change a bit)
Were I to compare these to a full-sized can, it would be the DT880 / 600 ohm. It's actually uncanny how similar they are (except for soundstage and general spatial qualities... of course). Both are incredibly bright. Both are remarkably detailed, clear and analytical. Both are mostly neutral and natural.
I listened to them for 2 or so hours at the gym, and then kept them playing (out of ears) at a slightly elevated volume (for 3 more hours) to 'loosen' them up a bit.
The comparison between these and the SM3 as I stated earlier stands, but dial back hyperbolae regarding stridency and harshness in the highs. That has subsided.
While these remain on the slightly thin and cool side of neutral, they are worlds apart from the SM3 because of that and their open clarity, detail, blah, blah. (Of late, the SM3 board has been buzzing about the mod of removing the little green filter in the tip. This has allowed the highs and upper-mids to come out from their captivity and apparently, the SM3 has emerged from it's cocoon and is now a brilliant super nova. Guess I sold mine too soon... ). The SM3 destroys these on the bass. No comparison. The DBA does not have the sonority or resonant richness of the SM3. But they still remain natural... mostly.
There is a frequency that is slightly elevated (haven't tested for it yet) that is causing a bit of fatigue. Moreso than either the SM3 or SE535 had. I never suffered any sonic fatigue from either of those. But here, now, after extended listening, I'm beginning to think it's time for a break...
Comparing the DBA to the SE535 is a more difficult task as they in broad, general terms cover similar territory. They are both mid-centric, but the 535's mids are more pronounced. The SE535 has wonderful highs... liquid smooth, but roll off way too soon, cutting off that last bit of 'air' and presence. The DBA's have that air. The DBA's have greater upper extension than the 535. Crisper and more sparkly, the DBA's define the location and breath of an instrument. Much like the DT880. Lower mids are more pronounced in the SE535 as is the bass and bass extension, but not by leaps and bounds. Just a bit. On the whole, the two are very similar with the 535 coming out ahead in refinement and tonal 'quality'. The DBA sound less 'acoustic'.
The DBA's have the comfort side won buy a long shot for me. They are light, the cables are light and short, they can be deeply (or shallowly) inserted, and twisted to different angles... which DOES change the sound. So that needs to also be experimented with.
The left-right designation is a joke. Buried beneath the glossy plastic is a miniscule letter (L & R) which is only visible under the right lighting and magnification. Good grief!
Of the three, SM3, SE535 and the DBA-02. It's the DBA-02 by a length. The ergonomics, highs and brilliance (now that they calmed a bit) have won me over. Not a perfect IEM, I could use a bit more sonority (well, actually quite a bit more). But the openness and clarity, speed and accuracy really cut it for me... much like my beloved DT880.
These don't need 70 - 100% volume as they drive fairly easily... but... they LIKE volume. They improve with volume and amping. Yes, no kidding. Fine for iPod, but throw some serious power behind these and they open up a lot more. Could be the newness... we'll see.
Cheers.
shane
EDIT... For those who don't know my MO: All files are uncompressed .wav, HD (24bit/96khz) or ALAC @ 24/48 or HD FLAC (24/88-96). Eartips for all three IEM's compared here were the same: flat-trimmed Comply. My standard test tracks used for all three. The only variables are the IEM's themselves, unavoidable and very minor differences in insertion depth, angle and seal.
Just in case you were interested...
