tf1216
- Jan 8, 2008
Out of curiosity, did you double-check the fit? I know in my own experience that every time I switch a cable it effects the fit of my CIEMs pretty significantly and given how low a margin for error there is with the fit of customs it can really effect the sound.
Hi DougofTheAbaci,
I haven't noticed a change in the fit. With the BaX cable, the monitors are difficult to remove because I have to grab only the shell to pop them out. The seal between the ear canal and the monitor is very tight. With the stock cable the connector has more bulk creating a type of handle to help with the insertion and removal of the monitor.
Have any of folks tried a 4-wire cable yet? The 4-wire has a separate wire for the return path for each earpiece.
