TheDreamthinker
So my Ck100Pro the left driver having audio shutter problem. So I send my cable back for warranty. But I soon found out it isn' the cable issue... It was the driver or connector issue. I have tried with other 2 MMCX cable. Swapping side and compare.. the result is the same..My warranty is already gone. So I'm just clueless now not sure what to do..
contact AT (or the entity you sent your product to) and ask them?
You must have had some sort of communication before sending it back.
If not, the worst thing that might happen is that you are charged for the false repair claim and need to redo the process.
