sridhar3
- Feb 27, 2011
Again with better/worse. This is TOTL gear. You need to find what best fits you. Are numbers and statistics of more import to you than the way it sounds? Does more horsepower or torque necessarily translate to a better car, or does implementation matter?
I liked the way the amp sounded. You don't seem to share the same taste in sound signature. Hence, this probably isn't the amplifier for you. Enjoy your KGSSHV!
If the KGSS and KGSSHV are so excellent, and the LL is more expensive, then there should be something that's even better about the LL, which is what? Based on your post, it's not the voltage swing. That's ok, but in what way does the LL excel?
![deadhorse.gif](http://files.head-fi.org/images/smilies/deadhorse.gif)
