So since these are my first CIEM i have a question about fit. I am still in my refit window. My right ear seems perfect, very little sore on the ear itself and i can barley tell they are in my ear at all. The left ear i have to twist a bit farther to get it to seal and when i do the back part of my ear where turns in and start folding at the top gets sore. Its like twisting to far and that part gets the IEM right on it. I only notice it when I have been listening for 3 hours or more and it goes away pretty quickly. Should i have them refit the left ear? Is this normal?
what is the normal amount of soreness on the ear after many days of long listening?
also, did you guys have to burn in your V3s?
P86 is probably a much better person to answer these questions than me (certainly the fit question), but I'll bite anyways
With regard to the fit, you've got a couple of weeks to see how it pans out. If you've never worn customs before, it may be a case of your ear (that left one in particular) adjusting to having a hard bit of plastic in it for a couple of hours at a time. Any discomfort
should subside after a week or two depending on how often you use them. With that said, you're in the US, 64Audio are in the US, so if it's still an issue in a week or two, definitely get it sorted within the refit period. Depending on the nature of the issue, they might tell you to get new impressions (which may be worth doing regardless). If you do go for a refit, giving them as much info as possible about where it's tight/digging in hurting will help them figure out what needs to be done with regard to them rectifying the issue.
Hopefully it's just a transitory thing for you though
So far as burn in goes, no I didn't burn in my V3's. I won't go into the why/why not/etc as that's probably best left for Sound Science :tongue_smile: And honestly, they sound the same to me after a crapload of use (>1000 hrs) Vs when I got them. YMMV, obviously though.
Edit to add - Congrats on the purchase, btw
You'll love the V3's. Yep, definitely a 'musical'/fun sound to just listen to for hours. Nothing really sounds bad through them (unless it's really crappily recorded).
