Roon has it's own built in Audeze presets. Reveal plugin is not meant to be used with Roon. Could you provide more information on what you are trying to do?Doesnt work with roon yet? Cant choose any of the New ones
Reveal Plugins - DSP for Audeze Headphones.
Just Wanted to try the New filter. I only have linear and low latency like before.Roon has it's own built in Audeze presets. Reveal plugin is not meant to be used with Roon. Could you provide more information on what you are trying to do?
Reveal has options to use filters shorter than the one in Roon for Pro Audio, the latency is lower in Reveal, but SQ is still as good or better with Roon presets.Just Wanted to try the New filter. I only have linear and low latency like before.
theMule2112
Hi, I wanted to share my findings on getting the latest Reveal+ v1.4.2 VST plugin working in Foobar2000. I was using v1.3.1 for a while without issue via the foo_vst 2.4 VST wrapper, but after upgrading to Reveal+ v1.4.2 I was getting constant crashes when starting playback.
The first way to get it working is to simply keep restarting Foobar2000 and attempting to play until it works without crashing, this usually takes about 5-10 attempts and once it plays ok you are good to go until you close Foobar2000.
Since I am a software engineer I was able to take a deep dive into the issue and figure out what is going on. I traced the issue to the way foo_vst is suspending and resuming the Reveal+ plugin quickly which causes Reveal+ to crash. I reported my detailed findings to Audeze and they may fix this issue in the next version of Reveal+ so we won't need a new version of foo_vst to get things working with Foobar2000.
In the meantime, I also create a patch for foo_vst (original source: https://github.com/yegorpetrov/foo_vst) that fixes the crashes with Reveal+ 1.4.2 if anyone is interested, please see the attachment. Please PM me if you would like me to send you the new foo_vst.dll with this fix since it's tricky to compile.
Thanks!
Thanks!
We have released version 1.4.2 that fixes the issueI reported this to Embody. They said they had Identified the issue and were coming out with a fix. That was earlier in the week
Great news. I've already downloaded latest version. Unfortunately unreadable size of font and too small plugin windows on high resolutions notebooks screen has not been fixed, making it really hard to use the plugin under Windows. Still waiting patiently to reply after passing this ticket from Audeze to Embody.
@KMann
Hi,
I just got my new LCD-i4 IEM yesterday. Got two questions here.
1, My main set up is A&K SP2000 player, do you have any pre-set EQ settings I can input to the player? Similar to the one in Reveal plugin?
2, If the SP2000 can't do it, then I can use my second set up, which is to use my phone(Samsung S20 ultra)+ USB DAC (Dragonfly cobalt). Do you have any app for the Android similar to the one in Iphone, so that I can have the preset EQ setting? Or do you have any EQ setting recommandation for Dragonfly DAC?
The reason I'm asking, is because I tried LCDi4 +CIPHER on my wife's Iphone, with Audeze app. It's a different sound than use on my Samsung or SP2000. And I actualy love it. But I can not justify the cost and troubles to buy another Iphone just for this.
So can you help me on this please? Any pre-set EQ settings for SP2000 or for Andriod phone with Dragonfly DAC? I want to have a similar result compare with Iphone or Reveal plugin.
I'm a newbie to Audeze headphones, so bear with me please.
Thank you
Hi,
Thank you
Ken G
Below are the Parametric EQ settings on my DAP (using UAPP) to mimic the Cipher DSP. I think this and other similar EQs have been posted here or on the LCDi4 thread.@KMann
Hi,
Thank you
In addition, the Anker adaptor at the link below will allow you to use the Cipher with any device that has a USB C output.
https://www.amazon.com/gp/aw/d/B07R6MKJZH?psc=1&ref=ppx_pop_mob_b_asin_title
edwardsean
- Jul 7, 2006
Did the issues with the linear phase filters every get resolved?
I just downloaded the newest build 1.5 and in Audirvana the linear phase filters cause clicking and popping during playback. There's no problem with the min. phase filter.
I always had some issues with Reveal and Audirvana on Windows including yours. The small screen resolution haven't been fixed while I reported it while ago and never heard back either from Audezee or Embedded after they've told me they passed the issue to software developer. I've switched to tone boosters plugin and I think it sound better on some tracks at least. The main thing is I never had any issues with tone booster software together with Audirvana. That also pushed me away from Reveal+ plugin purchase.
GU1DO
- Sep 20, 2015
hi
where the installer put the VST file ?
reveal 1.5
i want to use it with foobar
reveal 1.5
GU1DO
- Sep 20, 2015
never mind , i just found ithi
reveal 1.5
I am currently burning in my M15, cable and i4's I just got. I have been using KMann's 6 band settings and it sounds good, but noticed recently that Toneboosters now has 10 band PEQ. Could anyone help with a similar 10 band PEQ that mimics Reveal or Cypher please?
AlwaysForward
- Jan 7, 2017
@KMann Any plans to work with a partner on building this Into the onboard software for a hi powered portable DAC or DAP?
Audeze with Reveal is my absolutely favorite sonic signature with headphones. Being deep in the apple ecosystem, I’d be very interested in something portable or transportable to more easily access peak experience with your products anywhere, anytime in a more convenient way
We tried to work with A&K but things went quite after COVID, the best way to make request to the DAP/DAC manufacturer and we are happy to work with them.
