briant4pres
- Jun 13, 2016
Anyway free way to use this audeze reveal with tidal?
Help appreciated, thanks.
There are three ways:Anyway free way to use this audeze reveal with tidal?
Now that I actually have a pair of Audeze headphones, I thought I'd revisit this and see if I could get it to work with no luck, again. I guess my computer skills aren't adequate to unzip stuff to the right places or place .dll files where they need to go, or even if I had the right files. I followed all the instructions I could find (unfortunately they were bits and pieces here and there instead of the all the info in one place) and still, nothing. Oh well.
Can someone here tell me what the Reveal thing is supposed to do and how it affects the sound, if it does?
Our widely popular Reveal plugin applies carefully designed filter presets specific to our headphone models. These provide the producer/engineer with an experience similar to what they would hear from high quality studio reference monitors in an acoustically treated room (but without the pesky room reflections and reverb). We call this the Audeze Target Response. For professional applications, Reveal+ allows mixing and/or mastering in virtually any location while ensuring your work will translate well to most any system.
It's EQ/DSP designed specifically for your model to achieve a target sound. It's noticeable and apparent. (similar to cipher cable isine 20 vs normal cable) The effect it provides depends on the signature of the Audeze model you own (you select your model in the VST).
On windows just get 'equalizer APO', open APO's "configuration editor" click file -> new -> green plus sign -> Plugins -> VST
Click the file button to the right of the blank space next to your VST field and point to your reveal.dll (for example C:\Program Files\Steinberg\VstPlugins\Reveal.dll if you get the free/legacy pack from Audeze). ClickOptions/Embed(edit: this hides the apply button for some reason) Open Panel and select your cans, and File->save-> wherever\reveal.txt.
Use the "power on" button to toggle reveal in APO, and enable APO for your sound device in the top right, you may have to run APO's "Configurator" once to enable access to your sound output device.
Deactivate reveal (the power button in APO) when you're not using your Audeze. Active profiles stay active even if you don't run APO ever again.
I use reveal in a schiit eitr magni mimby with isine10's, without Reveal they are simply not as good.
I apparently have no idea what I'm doing. I followed your info to a "T", and the Reveal picture is now there with the gain and mix knobs, and in the upper right corner under "device" it shows the Schiit component but when I turn on the Reveal and adjust the gain or mix knobs, there is no change with the sound. I'm using a Winyl player but I don't get how the music runs through the APO and Reveal AND the Winyl player (it obviously isn't at this point).
With APO it's running near system level -- without getting too technical your player will not matter, (For example, my browser, spotify, tidal, etc all get the reveal treatment). When I first posted I had the "embed" option enabled, but you miss the "APPLY" button if you imbed the Reveal panel. This is my window:
(That curve also gives you an idea of what it's doing for the iSine 10) -- Full "wet" is 100% effect, and "dry" would be flat/no effect. With the Gain knob in the Reveal panel, it should be very apparent if the levels are changing. If you adjust the knobs, you have to apply (or use auto-apply). I found that if I modify settings too often with a source playing, something fails internally and I have to close my player / apo and re-open/initialize it to get it going again, because of this I don't "auto-apply" anymore (and rarely make changes anymore anyway).
If this doesn't work for you, you could try installing just for one player software, I know you tried foobar before but I'm not sure if you found the VST host plugin on their forums to really get it going correctly, I use musicBee and it's a similar process (not automatic) but jriver and winamp may have it baked in so it would be less configuration.
edit: *note my reveal.dll is renamed intentionally so I can tell version/architecture apart.
edit2: ASIO is not altered by the sound subsystem, so will NOT apply reveal.
edit3: unsure if "disable all enhancements" affects APO, other software requires I leave enhancements enabled.
I noted an edit on the post, but I named the reveal dll. I have the legacy and reveal + and the plugins come in 32 bit and 64bit variants, so I just renamed them so I could keep track. You may have issues with APO accessing %programfiles%, you could try putting the reveal.dll in documents\VST for example and see if that changes anything. My true working directory is d:\apps\vst and the dll is the standard legacy version that installed in program files (not program files (x86))Oh well. The Reveal folks tell me it no longer works with foobar, but even using music from Youtube, still no change. I was able to see and adjust the gain on the panel, and tried auto apply and the other way, but still no change. I just noticed in the VST plugin box, yours has "Reveal64.dll" but mine only has "Reveal.dll and there is no other .dll files in the folder. Hmmm.
edit:APO requires the 64 bit dll, but it will tell you if you're errantly trying to load the 32bit verison.
White is on (like your photo),I'm trying to get Reveal plugin to work with Equalizer APO and Tidal on my system, but I can't get it to work no matter what I try.
When I push the power on button, it turns black, so it should be activated? Is there something I'm missing?
I set the gain to -20db so I can immediately tell the difference when it activates.
White is on (like your photo),why is your gain at 0?derp. Did you run APO 'configurator.exe' and enable/install for your bifrost in that window?
