hag6
- Jul 21, 2015
Hi there, ok you can try this,
- Go to the same window where you added it to the DSP manager (File->Preferences->Playback->DSP Manager)
- Under active DSPs you now have Reveal ya?
- If you click once on the Reveal word, The "configure selected" button above that will light up.
- You can press that and it should turn on the Reveal plugin screen.
Thanks for taking time to reply. I got it to work - I didn't realise the the blue icon only occurs at the same time as selecting the VST option in foobar. Many thanks for your help. Did you find a good setting for the LCD2C?
