jaakkopasanen
Definitely something wrong if you get that zigzag curve. Iirc someone had something similar earlier in the thread but don't remember the solution from the top of my headHere are my graphs![]()
@jaakkopasanen what about mine? i got 2db headroom, why in the high frequency the graph goes very down and does zigzag?Definitely something wrong if you get that zigzag curve. Iirc someone had something similar earlier in the thread but don't remember the solution from the top of my head
The spring like shape from 500Hz to 5000Hz. Chaos is fine, but this isn't chaos and I don't know what would cause it.Whan you talk about zizag, can you precise wich ones ? The very small ones, oscillating around the curves ?
Perhaps the "humm" like a loop groud that i can ear : it's very slight, but if i increase the volume i can hear it.The spring like shape from 500Hz to 5000Hz. Chaos is fine, but this isn't chaos and I don't know what would cause it.
That stuff above 10 kHz is more or less expected.@jaakkopasanen what about mine? i got 2db headroom, why in the high frequency the graph goes very down and does zigzag?
@Xam198 download audacity and look at your headphone.wav, also if you can, try lowering the headphones volume and raise the mics or viceversa, try multiple times until you get a good sinusoid
The sinusoid should be pretty perfect, this is my test 3:
The volume made a big difference not only the loudness but to the quality. I don’t know if what you’re using is similar to behringer I use. But just try a recording based on how I fixed my issue. The volume can be fixed in eqapo afterwards.@ morgin, i use high volume on both headphones and speakers to have a lower input level on the zoom H5 to have a better S/N
I've tried with another comuter, i don't have anymaore (right now) the "qsssqsssqsss" at the end od the recording of sinusoid.
Here is the sinusoid recorded /headphones![]()
Google "causes of sudden hearing loss". There's a wide range of possible causes, some reversible, some not. She should definitely see a doctor. Good luck.This is a long shot but worth asking. I understand if I don’t get a reply for this and not really expecting one as it’s not a medical forum
But my mum has sudden hearing loss. She doesn’t listen to loud tv or headphones and doesn’t work near loud equipment. There’s is tinnitus too I believe that’s the result of the hearing loss. Do you guys know of anything to slow/prevent or recover the hearing?
Isn’t that something to go with grounding?I will try with lower volume and higher recording level, keeping a good headroom.I'm using a zoom H5, i hope my problems don't came from that, i will perhaps buy a umc202hd
But one thing that worries me is that "humm", a typical sound of ground loop : if the mic touch something, my finger, the earplug, i hear this humm - I monitor it directly to the zoom H5 . Then if i touch the vxlr, the hummm disappear. One mic do this, the other less. Anybody has experimented this ? The humm is not so huge, but i can differentiate it from noise and so if i increase the level of the H5 input do decrease volume, this humm will be more important. My mics are primo EM258. I ve tested pluggin the mics to a little mixing table, same thing.
