musicreo
- Jun 25, 2011
In the pre plots ( python impulcifer.py --test_signal="data/sweep-6.15s-48000Hz-32bit-2.93Hz-24000Hz.pkl" --no_room_correction --dir_path="data/my_hrir " --plot) you see that the left channel shows more noise. Audacity shows me that it is -45 dB on the left channel and -51.5 dB on the right channel. Only the SR,BR.wav does not show this noise in the left channel. Look at the waveform where I compare your FC-left measurement (the lower one) with my measurement (-56 dB). Actually the noise on the left channel sounds like a noise I had with some Pui capsulse when touching them.
At what distance did you perform the measurement?
