SonOfMorwen
Thank you for your reply. Is this the mount you keep at the end https://www.head-fi.org/threads/rec...r-speaker-virtualization.890719/post-16902907 ? If you have time, would it be possible to have more picture of your mount ? Especially to see how much the foam was cut and how you managed with the wires.Not sure about the cables.
But regarding the mics. The second link you posted is mine and I got better results not using those but using in ear foam plugs. I used a hot glue gun to stick mine to the foam and also cut the foam to a much smaller length so the mics were almost flush with my ear canals. The hot glue can easily be peeled off the mics if not much is used.
The foam didn’t slip as much and mostly stayed in place which I think was important
Hope you get some good measurements and don’t give up after a few tries. I’m still wowed by mine everyday and I did mine around a year ago.
Are you doing it for the surround sound?
Yes, at the beginning my main motivation was to use this for surround, but now I think that it must be very good for stereo too.
Did you try something else than the Primo EM258 ?
