me7
- Sep 8, 2007
Is the "phase shifted impulse response" (whatever that means
) audible? Can anyone who owns a 6G actually hear it when listening to music?
Originally Posted by Buckster /img/forum/go_quote.gif my classic here is sat in its box unopened - undecided whether to keep it and not worry about these "audio" problems - or send it back for £20 and get a 5.5G .. I had my fingers burnt with a IPOD Photo - which never sounded quite right - and was never corrected by Apple |
Originally Posted by Bob Mahoy /img/forum/go_quote.gif the main issue is uneven phase response; some frequencies arriving "late." |
Originally Posted by ozz /img/forum/go_quote.gif is there a bass increase that can be heard or is noticeable between it and the 5.5. |
Originally Posted by mirumu /img/forum/go_quote.gif I tried to reproduce the graphs linked in the original post since I have an almost identical computer setup to the person that measured them. The difference is that my Powermac G5 has a M-Audio Revolution 7.1 soundcard which I thought would be a bit more accurate than the inbuilt sound hardware of the Powermac G5 that he was using. I followed the method described measuring from the headphone output and my graphs look pretty much the same with a few exceptions. Note that my iPod is not one of the European volume limited ones so I can get higher output power from the headphone out. I still had room to up the volume but if I put it any higher than I used to measure these graphs with it started clipping and chopped off the tops and bottoms of the waveforms. First, the bass response I am seeing for the 6G iPod looks much better, this makes me think that the guy's speculation that his measurement hardware (i.e. Powermac G5 onboard sound) was causing the roll off is correct since my M-Audio card shows good bass response all the way down even below 20Hz. Also, my card doesn't roll off quite as quickly on the top end and it looks like 20Khz is achieved reasonably comfortably. I am still seeing a treble spike at the top end of about 0.1db but I'm sure that is just not big enough to be audible. Overall I think the frequency response looks pretty respectable. ![]() For the impulse response graph, I get the following which looks very similar to the graph he posted except it's spiking in the other direction. I don't know how to read this so can't really draw any conclusions from it but it certainly looks more like the graph he showed for the 6G than the one he showed for the 5.5G so I'm assuming that this is showing the phase problems. I do see that the amplitude of the spikes on my graph are bigger too although I don't know if that means anything important or not. Someone who knows how to read these will hopefully be able to summarise it better than me. ![]() Hopefully someone with Rightmark or some other measurement software can generate some graphs too just to rule out it being a problem with this FuzzMeasure software. My Windows computer's sound card is far too poor to give any remotely accurate graphs. |
Originally Posted by me7 /img/forum/go_quote.gif Is the "phase shifted impulse response" (whatever that means ![]() |
Originally Posted by Prozakk /img/forum/go_quote.gif Thanks for the info. But now I don't know if I should get an iMod or a 6g...ARGH! ![]() ![]() |
