Yes, it is awailable in 4 European countries, but EU has 28... They have notified Amazon, that they want to allow for shipping, to other than those 4 countries. But apparently it takes time.
Worked fine and sounded excellent for an hour, but I kept getting firmware update required mssg, so I did update . It then worked fine for another 30 mins before the left channel on 3.5 side packed up altogether.
Hey all — possibly a dumb question but I am curious, if I am using this with a Balanced connection to my earphones, is the “quality” that is hitting my ears via the Bluetooth AAC better than if I was wired via the Apple adapter dongle?
I’m curious more from a technical standpoint if the power via Balanced Bluetooth would make up for the wireless versus wired, if that makes any sense?
Just got my balanced cable yesterday (Penon 2.5-3.5). Sound seems fuller with it (Trinity Icarus III). I have no real interest in doing an A-B serious comparison. I now have a short cable to use with the Radsone on a shirt clip. Perfect.
Hi, sorry to hear about your ES100, just wanted to ask one question, did you lock the audio output to 3.5 assuming you're using the 3.5mm jack all the time? Thanks!
So sorry about that.
It seems that the unit has a H/W issue.
As we shipped a new one, and I hope you would enjoy it without any further problem.
Thanks for your patience!
WS
@Radsone team
I have an issue. When I charge the ES100, the unit turn on and connect to phone, I don't use ES100 when charging, so I have to manually turn off unit or turn off Bluetooth in my phone. It cause inconvenience every time I charge ES100. Any way to solve this issue? Tks
@Radsone team
Thanks for the heads up about that then. As I’d only just got it and hadn’t really had time to go through the settings as such, just to have a quick listen, charge and update it. Never got round to any other buds or ‘phones balanced or 3.5.
Just as well that I didn’t unplug my earbuds that I was testing it with.
