There is a shop in HK that have stock - search online for it... I bought from them 3.So far, after reading all the reviews, I'm wanting my self to get one. Too bad no shipping to Hong Kong from Amazon. @wslee when are you going to start shipping outside of US? Thanks!
Radsone EarStudio ES100
- Thread starter m4rkw
kevinscottcaja
Thanks man! I'll do some research tonight. Hopefully they still have stock.There is a shop in HK that have stock - search online for it... I bought from them 3.
posnera
- Dec 3, 2010
This is the best option I've found for my Icarus III so far. Haven't bought one yet since I don't use the Icarus much but I'm still considering it....
For some reason the link didn't show in my post but this was the one I was talking about.
Is there a version anywhere with a 90 degree plug for the 2.5mm end?
Can't remember seeing one. How would that work with the buttons on the ES100?
posnera
- Dec 3, 2010
Don't care about the buttons. I won't use them much. I can aways rotate the plug if it is in the way.
Installed 1.2, but when disconnecting from usb charger, the unit turns on.
Is there a possibility to keep it off after disconnecting the charger following charging with power off?
Thanks
Thanks
Coconut Wireles
- Oct 26, 2015
It's not ideal for the buttons. I use the CFA litz cable with the right angle termination and it is good in the sense that I clip the ES100 between my shirt buttons and it keeps it low profile but it does block the volume buttons for me. I could just turn the plug to the other side but it wouldn't orient nicely for the way I have the device clipped to my shirt.Can't remember seeing one. How would that work with the buttons on the ES100?
I do have to say that even using a straight termination 2.5 balanced does hinder my access to the play/pause/power button too by its close proximity to the plug. I'd rather have the play pause blocked though as it is easy enough for me to access that control from my watch or phone so I wonder if an option of locking the source volume when the ES100 is connected and having the phone volume control the analog volume of the ES100 would be a viable option.
Phase check on oscilloscope uncovered sad fact that standard balanced cables for 2.5 plug on sennheiser have wrong polarity but also left and right amps have different rise/fall time and make something like 10 degree phase shift of L/R. I will study more and post later after plug resoldering.
posnera
- Dec 3, 2010
Version 1.2.0 (May 8, 2018) released
- Crossfeed DSP feature added
- Microphone loopback during a voice call added (self-hearing through ES100)
- Auto power off on USB charger connection (optional) added
- DFU support for macOS
- Minor improvement in the voice call microphone quality
- Minor improvement in Ambient Mode latency
*macOS DFU tool is the initial version and may have issue with some environment.
Please let us know if any issue with macOS DFU.
Thanks and Regards,
WS
Can't get this to work on my Mac.
I unzipped the file and dropped run.sh into terminal. This is the result:
Last login: Wed May 9 19:55:59 on ttys000
xxxxxxxMBP:~ xxxxxx$ /Users/xxxxxx/Downloads/v1.2.0/macOS/run.sh
(kernel) Kext com.apple.driver.usb.IOUSBHostHIDDevice not found for unload request.
Failed to unload com.apple.driver.usb.IOUSBHostHIDDevice - (libkern/kext) not found.
com.apple.driver.usb.IOUSBHostHIDDevice failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
How to enter DFU Update mode through USB.
- Press and hold Power button and,
- Connect EarStudio to Windows PC through USB data cable.
- LED will be off, if entered DFU mode successfully.
Press ENTER to continue
When I press ENTER, this is the result:
I have the device in DFU mode - appears in System Information/Users/xxxxxxxx/Downloads/v1.2.0/macOS/run.sh: line 18: ./ES100_DeviceFirmwareUpgrade: No such file or directory
wslee
Member of the Trade: Qudelix
W'eve uploaded v1.2.0c package for MacBook compatibility issue.
Please check v1.2.0c package again and refer the pdf manual included.
(You need to install brew and libusb first as described in the manual.)
Thanks!
WS
posnera
- Dec 3, 2010
Thanks!
WS
Sorry, I don't see the download for 1.2.0c, only v1.2.0
Also, the pdf in the zip file does not say anything about brew or libusb
wslee
We've uploaded the package again.Sorry, I don't see the download for 1.2.0c, only v1.2.0
Please check EarStudio website and you will see the new package.
Thanks!
WS
CactusPete23
At this link http://radsone.com/EarStudio/firmware/v1.2.0c.zip The Readme file mentions those files. Sorry, I don't have MAC to test...Sorry, I don't see the download for 1.2.0c, only v1.2.0
posnera
- Dec 3, 2010
Thanks!
WS
OK. I've found the c package and unzipped. I installed brew, waited for it to finish, then installed libusb.
Then I dropped run_macOS.sh into terminal and I am still getting this error:
/Users/xxxxxxxx/Downloads/v1.2.0c/run_macOS.sh: line 16: ./ES100_DeviceFirmwareUpgrade: No such file or directory
Sorry, all of this is foreign to me. Thanks for all your help.
wslee
After opening the terminal, you need to go into the v1.2.0c directory that is unzipped.
cd Downloads
cd v1.2.0c
./run_macOS.sh
Hope this works.
Thanks!
WS
Total: 27 (members: 0, guests: 27)
