Coconut Wireles
- Oct 26, 2015
Just received one from Amazon and found someone opened the device before!! There are marks around the case showing someone was trying to open the case and then returned it. Very disappointed that Earstudio will send a refurbished item to a new customer.
As in opening the ES100 itself? I don't know if my box was shrink wrapped or even taped close but my device looked flawless. You could consider asking for a partial refund from Amazon or the return should be easy enough. They'll probably let you hold on to the one you have and use it while you wait for the new one to arrive.
Mine from Kickstarter came with some scratches on the device too. Didn't look like it was an attempt to open it but there's circular scratches around the 2.5mm port like somebody tested it and spun a cable in there that had some sharp metal on the jack.. Also a few minor surface scratches in various spots. I've been using it regardless but it annoys me when I see them.
Yesterday I was asking Venture Electronics if they're able to make me a 50 cm 2.5mm balanced cable and they've confirmed that they can so I'll order one from them when I get home from work this evening. I'll let you know what the final price ends up to be.
Awesome! Very interested to know!
What IEM connector are you using on the other side / do you know what choices they offer?
Thanks
what is the warranty period for the earstudio?
I'm so sorry about that.
Although, we don't sell or ship any refurbished item,
I have to admit that we've been getting the similar issue from some users.
We've been working on that issue and trying to improve the end finishing as best as we can, with the Manufacturing and Quality Control department in China factory.
Apologies once again, and please contact support@radsone.com if any issues including the above. We'll support you with the best.
Thanks and Regards,
WS
From the Kickstarter page:
"Radsone provides you one-year limited warranty service on manufacturing defects on hardware. EarStudio supports DFU (Device Firmware Upgrade) functionality; users can easily update the firmware through USB cable with the PC."
Now waiting for EuropeCanada, in stock
