wslee
Member of the Trade: Qudelix
I use a FIIO BTR1 for my Beyerdynamic DT770 32Ohm. Sound quality is good, but I need more power. Is the Radsone EarStudio more powered? Is there a difference between the power of the 3.5mm se and the 2.5mm balanced output?
FIIO BTR1 has AK4376, while ES100 has AK4375a.
Both DACs support the same output power, and H/P amp gain up to +6dB.
I'm not sure FIIO BTR1 AK4376 H/P amp gain configuration, but as I check the specification,
http://www.fiio.net/en/products/77
it seems that ES100 provides slightly more power with no distinguishable difference, I guess.
ES100 2.5mm output provides much higher power,
but DT770 doesn't support the balanced cable replacement.
Thanks and Regards,
WS
