kukkurovaca
- Apr 7, 2017
That's low impedance. The ES100 (and most amplifiers) will drive it with more than adequate power.
But it's a Q701 I had in mind....
Even if impedance is low, insensitive headphones may be difficult to drive. I haven't used the Q701 but plugging numbers into a calculator, I'd say that you might be pushing the ES100's single-ended capability, particularly if you want headroom to EQ. For comparison, my GT3 Superbass are a little more sensitive (going by specs) than the Q701 and I find them to sound a little thin using the ES100's single-ended output and EQing.
