PiSkyHiFi
- Dec 15, 2009
I can't test Apt-x HD. It's possible that it's superior to AAC. Aptx is sub-band ADPCM low complexity codec that basically cuts bits based on a frequency. Unfortunately, that leads to clearly audible high-frequency noise and in ES100 case it sometimes leads to amplification of aptx harmonics and brings sand noise. I'm completely confident that I do not hear 24vs16 bit difference at all (as well as above 44.1 sample rate). In fact, I don't believe anyone can pass blind test of properly dithered 16bit 44.1 vs anything above. But aptx is not even true 16 bit, so aptx-hd maybe solves that issue. But I don't have sources for it - there is no aptx-hd in S8 or Windows or OSX. And there are no USB BT that has it. And Radsone decided to save cost of LDAC certification (which is fine) which I at least can use in Android 8.
At the same time, AAC is vastly superior codec to aptx for music and it works on most sources now. Yes, it has a latency issue, which I couldn't care less for music. Plus it cuts >18kHz sound (I don't hear anything there doesn't matter volume). Plus it generates a lot of harmonics which human ear can't hear anyway at such bitrate. Maybe it drains a battery somewhat faster. While aptx generates stupid noise that anyone can hear and somebody might even like that since it bumps high frequencies up.
Somehow there are no real test studies published on Aptx HD (Qualcomm signs hush agreement with partners?), but I would assume AAC could still be superior just because it's smarter and I have a feeling that large bandwidth of Aptx-HD only used for high sample rate and not for preserving even first 16 bits. Anyway, it's just my speculations and I could be wrong.
I still insist something is wrong with the implementation of aptx in ES100 (or with combination with my sources), but it's easily could be a fault of CSR itself, I don't know - need more tests and therefore more time.
But AAC with sharp filter is good enough for me. And in such form, I like this device a lot - if only AAC can be fixed.
I can drive HD650 in balanced mode, but I wouldn't say it's loud enough for going outside. 600Ohm, I guess should be not enough volume even for home use.
Jitter Cleaner is a complete gimmick by CSR, IMHO - AKM is jitter resistant already and whatever happens there is so much below rest of noise that I wouldn't bother - if it works, fine, if not - turn it off and don't look back.
P.S. I'm reading DCT patent details https://patents.google.com/patent/US20130216059A1/en + http://radsone.com/radsone-home/doc/Radsone DCT.pdf and it sounds like some spatial reverberation technology to make slight room effect + clarity filter afterwards. It could potentially improve psychoacoustic data restore like AAC. So since there are many tests made by Radsone - @wslee, that would be great to hear about results in laynman terms. Since LG, Astell&Kern and Audio Technica decided to license this from Radsone - there should be clear benefits.
I agree that AAC is the best codec at the same bitrate, it is also the most expensive computationally, which is no surprise.
I also agree that well mastered 16 bit 44.1 can't really be improved upon for nearly all human ears - they won't distinguish it from anything better, mine included, but you also need a decent analog stage of course.
I believe the jitter cleaner is just the method they used to resolve the clock differences between source and sink. When using USB isosynchronous mode, buffer over-run and/or under-run are bound to occur in this configuration, causing audio resync which will be audible. The better solution is to use asynchronous mode, where the sink has the only clock and it controls the flow of information maintaining the buffer without any need for resync. It needs more circuitry though and so adds to cost.
I get the impression the cleaner is a sensible no-audible resync using DSP, I don't know for certain though, that's my interpretation of what WSLee said in this thread. It's a good method for the limited hardware.
I've witnessed cheap Bluetooth adapters actually slowing down the music and speeding it up to maintain a consistent buffer.... kind of shooting itself in the foot really, so glad I can avoid that stupid thing now.
All of this will be moot in a few years.... eventually Bluetooth will be able to transmit standard uncompressed audio, so all these patents and attempts to resolve complicated compression issues will disappear.
