Lurk650
The only annoyance I have with the updating is getting it into the update mode, its took me over 5 min to get it to connect so I can update it the other day. The manual says it doesn't matter how long I'm holding power button for but I find the opposite lol. Then bc I'm on Mac I have to do a bunch of retitling so it's in the right folder for the Terminal to find itI noticed that the "Partial charging" battery setting was reset after the firmware update. If you use this setting, change it manually after updating firmware.
Firmware updating is an area that Radsone could improve. It should not be necessary to open a command line, or even to unzip a file. The firmware could be packaged into an installer such as InstallShield on Windows or a .pkg file on Mac, and the installer can run the necessary steps to install firmware. The installer can also guide the user through all of the steps.
https://en.wikipedia.org/wiki/List_of_installation_software
Ideally, firmware would be packaged into the EarStudio app, and updates performed by EarStudio over bluetooth.
i think i don't mind the PC update because it's not like an every week thing. Of course app update is vastly preferred, still, not a big deal.
I'm still in the middle of comparing ES100 and Shanling M0. After the update, personally I don't see Shanling M0 getting more advantages over this.
Too bad Shanling M0 BT receiver mode battery is too bad despite of the larger battery. ES100 can last 13hrs comfortably and way lighter.
Anyone else that have both can verify the battery run time b/t these 2 devices please?
P/s: new update amazes me. I didn't know they can add support for BT 5.0. Always thought that's a hardware thing.
I just got the M0 the other day, I prefer the more solid build on that but of course that means its also heavier. Have to spend another $15 for the clip accessory sucks. It lacks 2.5 but does sound really good out of the 3.5 using an iBasso 2.5 to 3.5 adapter. Barely tested the LDAC streaming briefly last night and it was solid. The most cumbersome part of the M0 is having to turn on the screen just to change the track (not in BT mode of course) and on top of that the touch UI is not good at all (latest FW updated).
