voidedsoul
- Jan 31, 2017
Only based on SQ Shanling m0 LDAC or ES100?
If you change volume on Apple Watch, doesn't it affect any connected Bluetooth device (including ES100)?It's a shame this doesn't have sound link. I like to control volume with my apple watch.
Would you say a mobile phone connected to Fiio Q5 Mark II sounds louder and better than connected to ES100 for Athm50x?
Then it seems like a problem in Apple software. The iPhone should control the ES100 like any other generic Bluetooth audio device. Do you have a problem with any other device?Meant volume sync.
Radsone explained this - volume sync allows only about 15 steps, and they want to support a lot more.Rkw it is well documented in this thread and the Fiiio BTR3 thread that both devices opted not to give volume sync as an option. You don't know what you are talking about so why jump in with a comment like the above?
With volume sync iOS pumps out full volume from the source and volume adjustments are made to the Bluetooth device itself. This is how my Sony MDR1000x interact with my iPhone.
The ES100 and BTR3 both skip this feature, the volume on the BT device and the source can be set independently. This means that adjusting the volume on the phone has a destructive impact on the audio as it is made digitally before the AAC transmission rather than after it's been decoded on the BT device. For optimum sound you need to set the volume to max on source then control it with the device. This is how it behaves in my car for example and there's a clear drop in audio quality if the source isn't at max volume, making the source thin and tinny.
It's a disappointing ommision as the vast majority of current BT devices support this feature. It means that any attempt to adjust volume with the source impacts sound quality so you need to run that at max, doesn't matter if it's iPhone or Android, and adjust.volume on the device. Unless you don't mind thinning out your sound.
Just a misunderstanding. You wrote "I like to control volume with my apple watch.", and I took it mean that you weren't able to adjust volume at all from your watch.You don't know what you are talking about so why jump in with a comment like the above?
This little device is simply incredible. I’ve been using it for the last 3 months and it’s changed audio for me completely. Running the Tin Audio T2 through a silver balanced cable is purely ecstatic. It also drives my HD 58X pretty well, as far as I know.
I just wanted to ask you guys if the ES100 is capable of adequately driving the HD 600. I have a balanced cable for the Sennheisers, but I’m not sure if I should buy the HD 600 if the ES100 would have trouble driving them.
I actually can’t decide which I like better. The ES100 has a much better portability factor along with more options (3.5mm and 2.5mm balanced + the app), but the M0 has the ability to use alone without Bluetooth because it’s a DAP. From a purely sound quality perspective, I think it depends on your use cases and IEMs/headphones. The M0 sounds very good with BA IEMs because of its super low output impedance and is lossless when not using Bluetooth. The ES100 is perfect for more power-hungry stuff like my HD 58X. They sound a good deal better than the M0 if you’re comparing the Bluetooth audio quality of both; but the M0 might sound better if you’re using it as a DAP without Bluetooth. Me personally, I use Spotify and Tidal a lot, so the ES100 wins in that regard.Hey since you got M0 and es100, which has better SQ?
If the ES100 isn’t available in your area, then the M0 is a great alternative. They’re both very good and capable devices.Read that M0 uses the ESS DAC even for Bluetooth data, but not sure about it. Unfortunately ES100 is not available in my country, only the BTR3 and M0 are my options. But if the SQ is a big difference will try importing from Amazon
