Radsone EarStudio ES100
Jul 9, 2018 at 6:56 AM Post #1,546 of 6,675
Screenshot_20180709-124641_EarStudio.jpg Screenshot_20180709-124711_EarStudio.jpg Screenshot_20180709-124755_Settings.jpg Screenshot_20180709-124803_Settings.jpg Screenshot_20180709-124816_EarStudio.jpg Cant seem to get ldac running on my samsug s8 with the earstudio. When i choose the ldac codec in bluetooth settings the earstuido app dies and restarts changing to sbc from atpx. Cant even see ldac in the codec list in earstudio app. Running fw 1.3.0
Jul 9, 2018 at 7:09 AM Post #1,547 of 6,675
Update app
P.S. Thanks for screenshot - I found how to fix LDAC to stick! If only I also knew how to fix it at 44kHz now instead of useless 96khz.
Jul 9, 2018 at 7:25 AM Post #1,552 of 6,675
awesone job to wslee and the whole team of Radsone!
Jul 9, 2018 at 7:34 AM Post #1,554 of 6,675
Well, LDAC and power features are cool.
iPhone doesn't support LDAC. That means pretty much everybody going to have the same story - LDAC won't be actually used on a daily basis. While Radsone will be paying license fees for it.
H
Are you kidding me, not everyone has an Iphone... LDAC is a standard Bluetooth codect after Android 8.0, meaning that nearly every android device in a couple of years will support LDAC. Also when it comes to buyer of this product I'm fairly certain most android users will already have a pretty new android phone that supports LDAC.
Jul 9, 2018 at 7:43 AM Post #1,556 of 6,675
Chill out, mate. I found how to fix it already and updated post :)
Jul 9, 2018 at 8:10 AM Post #1,557 of 6,675
Sorry if this issue was addressed before.
With my LG V30+ which provide better audio quality? LDAC 24bit or APTX-HD 24bit?
The system default on my LG V30+ (when connecting to the ES100) is now LDAC, although I can change it via Settings/Developer Options
Thanks
Jul 9, 2018 at 8:13 AM Post #1,558 of 6,675
The system default on my LG V30+ (when connecting to the ES100) is now LDAC, although I can change it via my Settings/Developer Options
Thanks
I would assume LDAC - it's adaptive to connection quality.
Quick first test results: on Mosquito test https://www.audiocheck.net/audiotests_mosquito.php APTX makes horrible clipping noise, LDAC doesn't do clipping noise but have quite an audible aliasing except 300kBit connection where I assume it's just ditching high frequencies completely. Change of frequency of codec doesn't change anything - aliasing is there, but finally - no clipping.
Jul 9, 2018 at 8:14 AM Post #1,559 of 6,675
Hi everyone!
I was finally able to order the ES100 to Sweden from Amazon UK. I'm expecting it in a few days.
I ordered the Beyerdynamic iDX 200 iE as well (https://europe.beyerdynamic.com/idx-200-ie.html). I'm a bit worried they won't work with the ES100 because of the remote control on the cable (and extra pins on the connector). Does anyone know if headphones with remotes work with the ES100? I don't care about the remote not working, I just don't want to break the ES100.
BTW, what do you pros think about the iDX 200 iE? Crap compared to your pro IEMs? :D
I have an other question as well.
In USB DAC mode with Windows 10. Will the ES100 work in low latency applications like music production? Does it support the new Windows WASAPI or ASIO4ALL?
/E
