Redmetal1897
- Nov 5, 2010
I can get you a head start.
Fit, comfort, isolation MD>DDM2.
Well, [size=medium][size=medium]Dimitri's office is in Tokyo and I hope they are alright over there, but foreseeable the launch of DDM2 will be affected by such a large [/size][/size]quake since everything is shutdown now.
can't wait till i get my pre-order DDM2.
Had a brief listening to these. The fit and isolation (latter only slightly) is better but it's the same cable and the build seems to resemble the first. In terms of sound they are more balanced but it's still overall a very similar signature. The treble is more present and doesn't sound as recessed, the mids seem to be about the same quality while the bass seemed to have a bit more refinement. The signature doesn't sound that strange in it's presentation anymore it seemed, unlike the DDM which can sound very off at times.
I get the feeling from early observations from ppl that the DDM2 is just the DDM in different housings with tuned drivers to get the balance right. Hmm, thats a bit sad as it means the sound quality will probably be about the same. Would have been nice if there was a driver upgrade or cable upgrade at least. I was tossing up between these DDM2, Fischer DBA2, Brainwavs B2, AT CK10, Monster Turbine Copper, Westone 2 and I hope my decision to go DDM2 was right, it just feels like $250 was too much for these, paying $100 bucks more than original DDM and not really getting anything new.
So the mids are still grainy?
