Thanks. We must surely end this ghost discussion. Possibly this remains a mystery for ever, I haven't been able to figure out the designer or contacting the main seller either. I can anyhow return the cable to the private seller during next couple of weeks.
If I may try to contribute based on earlier entries deep in other threads by
@Aleksandar R.
Because of the extremely low impedance of the ribbons, all of them, the cable becomes a critical part of the chain. Raal designs the cables specifically for each different headphone to give a full frequency response. Conventional headphones do not have this requirement and so exotic cables and designs can simply have the right terminations applied and they can be marketed as better (and maybe they in fact are).
With the ribbons, simply applying the right pinouts and terminations to what may otherwise be an astonishing cable for conventional headphones may not work well with the very specific demands of the ribbons.
Unless a cable maker has consulted with and/or already knows the targeted impedance for the cable, or knows how to calculate it for the impedance of the ribbons as Aleks does, then everything is just a roll of the dice.
For this reason, the Raal cables are not simply a fancy "upsell" to the headphones, but more or less part of the headphone. Speaking for myself, I'd be fine if they soldered them strait into the headphone as is done with the Valkyria for example.
I may be stating something you already know, but I'd be wary buying a 3rd party cable simply terminated and pinned correctly not to blow up with the ribbons unless it is verified the cable's impedance was well considered for the Raal headphone. In fact, early in my ribbon adventure I spend $$$ on a famous Japanese cable and it was not successful with the SR1a, to my ears.
Just my two cents.
