Multiple drivers = more complex design.
One of the highlights of the single ribbon in the SR-1b is it's pure coherency.
Adding additional drivers may make it difficult to preserve it.
In any case, it'll be interesting to hear impressions, and possibly later to try out.
I'm still learning my SR-1b and it is certainly not a plug-and-play headphones, it is very finicky and requires many tweaks and matching gear to shine.
Just ordered the star-8 cable.
Thank you for bringing the coherency question up.
IME, this is not a real problem. More of a philosophical problem, knowing that two (or more) of the "same" things aren't exactly the same...
However, look at it this way: there is a single driver surface area that has been divided into two or more sections.
I did a lot of ribbon and cone-midrange drivers in tight arrays back in the day, sometimes tapering them, and all is normal and well and nothing happens, as long they are in phase, like they would be if they were parts of a single cone, "coupled" by shared air loading (unlike in MTM arrays).
This time, I'm doing something that could be called "complimentary tuning", which in essence is a slightly different tuning of ribbon sections in a duo or a trio. What this does is that when a dip in response of one ribbon appears, there's no dip in it's mate's response, so one fills the holes of the other and vice versa.
Air load sharing happens normally, so they are well coupled in overcoming radiation impedance of air.
With complimentary tuned diaphragms or ribbons, you don't get multiplication of a problem. You get local field (less than 1/2" away from the ribbon) exchange of pressure between high pressure (peaks) and low pressure (dips), so the far field response (of the whole surface area) is smoother.
That is why, back in the day, B&W came up with weaved cone midrange drivers (Kevlar in their case), as there is the same mechanism of smoothing out the far-field response with weaved cones. Their different stiffness and speed of sound in different directions of the weave is basically dividing the diaphragm in sections with different tuning (4 sections tuned one way, 4 sections tuned the other way in a 90° weave).
Those cones do produce peaks and dips in pressure, in sections of their surface area, but that gets cancelled out locally.
Unless you do a close-up point-to-point measurement (or an inteferogram) of the cone, by measuring in far field, you would not be aware that there are local problems, or that there is (a multiple) cone breakup.
Things are just smooth and nice in far-field and they sound as clear, detailed and smooth as can be.
So, this is not just about increasing the surface area of the ribbon, it's also about reducing the problems that a single one has, or any other single diaphragm has, for that matter.
