Ever considered the Schiit Jotunheim R (or A):
https://www.schiit.com/b-stocks
Changes the Raals into an integrated system at currently very low cost, specially if you have the DAC option installed.
The Jotunheim R has a slightly more bodily experience than the interface box on a very good amp here.
I think this is linked to it’s slightly stronger baffle compensation, together with it’s sheer power/current capability of 13 Ampere, equaling a speaker amp with 676 W / 4 Ohm, or 1352 W into 8 Ohm!
I have the Schitt JR and hardly use it. It is the worst of my RAAL setups, and I have had a lot of RAAL setups,
- HSA-1b
- Schitt JR
- 10-12 2-channel amps with old interface box
- VM-1a
- CODA #16 | PeachTree GAN400 | PeachTree GAN1 (modded) | TL-1b adapter
- Mitch's old SR1a filters
The very best is the VM-1a with my Benchmark DAC3b or Lumin X1 DAC, both doing fibre optic streaming via ROON. I did not like the Musetec 005 DAC with the VM-1a (too smooth). Though that DAC was good on 2-channel.
The worst is the Schitt JR, though Danny has told me that the new Star8 cable makes the JR sound better. I have the Star8 but have never tried it with the JR.. I am only keeping the JR around since it is so cheap and a good backup.
My desire to change things up is because I finally found something that I like better than the RAAL phones. It is the Yamaha NS5000 speaker with my CODA #16 amp. It is better than the SR1a with the VM-1a. I am not a fan of headphones but love the 2 RAAL phones, and for the past 5 years nothing could beat the RAAL's in my mind, even 2-channel.
My $995 Magnepan LRS+ speaker in my small office is very much like the SR1a. You need good amplification to make them shine.
My ranking of my systems is as follows:
1. Yamaha NS5000 | CODA #16
2. SR1a | CA-1a| Star8 | VM-1a
3. Magnepan LRS+ with PeachTree GAN1 (modded)
I can make the Magnepan sound better and also be more useful (add my analog sources) with a different 2-channel amp (or integrated). I will sacrifice some headphone excellence by selling the VM-1a to improve the Magnepan sound. I listen to the Maggies 8 hours a day (M-F) and the RAALs about 3-5 hours in the evenings when I work some more.
I was thinking it over and I do not think an integrated amp will work with the TL-1b adapter. A 2-channel amp will be what I should get + another DAC since I only have 1 left.
