paulpaul
- May 1, 2015
HiThe Interface box sizes are: body- 124mm wide, 170mm long, 40mm tall and the face plate is 134mm wide, 50mm tall and 10mm thick.
With carbon shells/cages, fit is superb, as that part is all about exact dimensions and holding the innards firmly and precisely.
Finish...the best we could muster out from Carbon Fiber board with exposed edges and pouring the epoxy resin that holds it together. The dosage of epoxy turned out to be a non-trivial matter, so not as good looking as we wished for, but it is not a crime for a ruggedized product that is all about pro-gear toughness.
The Interface box is a regular electronics box with a good fit and a fair finish, but nothing fancy. It does the job and it looks appropriate for the context in which it is in (pro gear).
All in all, SR1a are not the prettiest thing you'll see but it doesn't aspire to be. There's a stripped down, bare bones tech, vibe to them. Visual design for the sake of beauty is almost non-existent in them...all that is there, serves a purpose.
Anyhow, they are very impressive in their own right. A young couple at Denver Canjam joked that they are the Darth Vader's evil brother's headphones
Our next model(s) will be a circumaural pads, open and closed backs which will look much neater. It is much easier to make them such, as like with other headphones, they will have bezel rings that cover grille edges and the structure will be hidden. But, I give no promises! Maybe they will also be anti-fashion statements, as well!
I am about to hit the button. You mention the upcoming model and I would like to reconfirm that you are not talking about weeks or a few months down the road.
