not sure if this is the right thread for this but i didnt find a JotR specified thread so i posted this experience here. i haven't listen to my JotR and SR1A setup for a while and while i enjoyed the beautiful performance of my utopia this morning, i suddenly wished to compare the two.
i listened with tidal for a few songs (still superb performance and no less from the SR1A
) and then switched back to the utopia for an hour or so before i reached to my SR1a again. btw, i stacked my jotR under my computer monitor and above the topping A90/D90 stack (which i used for most of my overeras) for convenience (not particularly well ventilated but not closed/covered).
but when i switched again to SR1A after an hour or so, there's quite audible clipping on the treble from the right side driver! i tried different songs and switched between footbar, spotify and tidal - all the same with the "ringing" kind of clipping sound! i touched the JotR and it's quite hot to touch and it's already lunch time anyway so i turned off everything and went out. i got back home evening and switched back on the the JotR to see if it's the right side ribbon driver clipped. luckily, after cooling off, everything back to normal! gayle and jax both sang beautiful without any audible noise/clipping.
i just wonder if that's the limitation of jotR (e.g. out of the operating temperature range)? Schiit actually advised never to turn it off but i found the unit consumes the same amount of power (~15W) no matter music is playing or not so i actually turned it off most of the time as i didnt often listen to my SR1A (i personally hear no substantial/audible difference whether i warm it up or not). i guess it needs to dissipate 15W of power when idling this morning similar to a class A amp. maybe that's what caused the clipping in the morning?
